Control Font at runtime?
I want to be able to set the font that will be used for a field on a report at runtime. Is there any way I can do this? I have a receipt printer that uses proprietary fonts to handle some special functionality, but I don’t want to hard code the Font Name into the report, so I can keep the function as generic as possible (also they have 2 different printers that use different fonts) Thanks Darren Bezzant, NCPS, NCSD Central Software Ludlow, New Brunswick, Canada dbz@nb.aibn.com
In request form, you can go to file, Prepare page, and then modify Font. It’s saved in Zup file. It’s only for this machine and report.
The Problem Is that in my ‘perfect little world’ I would like to be able to assign the font from a Datafield. This way the end-user can determine which font is used for this report. Darren Bezzant, NCPS, NCSD Central Software Ludlow, New Brunswick, Canada dbz@nb.aibn.com
You can create bodies to each printer and use funcion CurrReport.SHOWOUTPUT if user profile is correct
