I have installed AX 2012 R2 CU7 on my local test environment. Now I want to to upload contoso demo data.
I want to know that is there any other separate contoso demo data for CU7, or I can use previous demo data to it.
Pls help.
Nitish
There is no separate Demo Data For CU7 is available, You can use the existing data.
If you are using a previous demo set, you will get a checklist to upgrade the data to CU7. If you want to prevent this, you can download the AX 2012 R2 CU7 VM from Customersource/Partnersource and create a new backup file or use the Test Data Transfer Tool to export the data.
