ATrain
April 7, 2011, 12:14am
1
Is there any way to “bound” a string in a where expression? DocuRef.Notes is unbounded so it errors. Here is the code:
while select forupdate docuRef
where docuRef.RefTableId == TableNum(SalesTable) &&
docuRef.Name == ‘Order Notes’ &&
docuRef.TypeId == ‘Note’ &&
docuRef.Notes like “SearchString ” // ERROR HERE
docuRef.TypeId = ‘NewType’;
docuRef.update();
You cannot use the Memo fields in the where expression…
You should find an alternative to achieve the above - like removing it from where expression and using an if condition.
ATrain
April 7, 2011, 4:31pm
3
Kranthi,
That’s what I thought I might have to do, but I wasn’t sure. 100,000+ records, so it will be slow, but it’s a one time update so we will just roll with it. Thanks for the help!
