Hi everyone,
As you can deduce from my latest post, I’m making developments for integrate BC with external services.
I am creating a function in a codeunit that should return a text variable to an external service that calls it. I’m testing it on postman, but I’m nto able to connect it:
As you can see, I’m getting a 500 internal error. The user and password I’m using to authenticate are the ones I use to log into BC. Tee codeunit is published as a WebService, as I’ve always done:
May be this can be a permission issue or something like that?
