Consolidation error message in dimension
I tried to consolidate someanies, Financial Management > General Ledger > Periodic Activities > Consolidation > Business Units then I select Functions > Import Database, and appear this message
“Another user has modified the selected dimensions for the copy dimensions field after you retrieve it from the database. Enter your changes in the Dimension selection window by clicking the AssistButton on the Copy dimnesion field”
The only change that I did was change the Dimension code of the country, do you know how to fix it?
