Consolidated Trial Balance
Dear All,
I have a consolidated trial balance report which has six entities. only one entity is appearing in the report with values other come with 0 value. I did all setup for columns.
please could you advice
thanks
Ayoub
How are you running the consolidated trial.
You need to consolidate all the 6 entities into the consolidated entity and run trial there. Verify that all the 6 entities are consolidated properly.
You can also check this in Management Reporter.
Pranav…
Hi Pranav,
Yes I have a consolidated company and the consolidated data from other entities in that company. I checked the ledgerTrans all data from all companies are there.
But I wonder, how data from only one company comes properly in the trial balance report column?is there any other setup need to be done?
Ayoub …
Well, balance should be updated in trial balance. Did you run Re-Build and Update balance? Also, in consolidation company in General ledger, Inquiries, are you able to see all the 6 entities.
There may be something wrong with consolidation process also. I will suggest to cancel the consolidation and re-run it also.
Pranav…
I checked the report. the report is getting data from LedgerBalancesDim and this table doesn’t has a consolidated company filed. so I changed the report to take data directly from LedgerTrans because LedgerTrans has a consolidated company field.
Now the report is working fine.
Ayoub
