I restored a database called NPFDB1 into MS SQL SERVER “DESKTOP-T6U5FJC\MSSQLSERVER2014”
In the Database (Server Instance table) Server Computer Name was “devtestserver.npfpensions.com” and changed it to “localhost”
I run this SQL Script:
USE NPFDB1
delete from [dbo].[User]
delete from [dbo].[Access Control]
delete from [dbo].[User Property]
delete from [dbo].[Page Data Personalization]
delete from [dbo].[User Default Style Sheet]
delete from [dbo].[User Metadata]
delete from [dbo].[User Personalization]
GO
I later check the tools > Options and Files > Database > Information. it was set and restarted both the Instance and NAV Server Administrator
After I run the role tailored center error message occur “The Program could not create a connection to the server. Do you want to try again?” Please I need your help, have done all I know about Client config. Thanks
My Client Config:
<?xml version="1.0" encoding="utf-8"?> <!-- Specifies the sign-in page that Microsoft Dynamics NAV redirects to when configured for Single Sign-On. For Azure AD (Office 365) authentication, the WSFederationLoginEndpoint setting has the following format: [login.windows.net/<AAD](https://login.windows.net//wsfed?wa=wsignin1.0&wtrealm=&wreply= Where "" is the ID of the Azure AD tenant, for example "CRONUSInternationLtd.onmicrosoft.com". "" is the ID that was assigned to the Microsoft Dynamics NAV application when it was registered in Azure AD, for example "https://localhost/". "" is the reply URL that was assigned to the Microsoft Dynamics NAV application when it was registered in Azure AD, for example "https://localhost/". The following ensures that Microsoft Dynamics NAV redirects to the right sign-in page: - When NAV is configured for single-tenancy, just write the URL with has the same format as specified above. Like the client-side ACSUri. - When NAV is configured for multi-tenancy, and the corresponding AAD application is also configured as a multi-tenant application, use "common" as the {AADTENANTID} value. - When NAV is configured for multi-tenancy, and each NAV tenant corresponds to an AAD tenant, which contains an AAD service principal, use "{AADTENANTID}" as the value. NAV will automatically replace that value with the value that was used when mounting the NAV tenant, for example login.windows.net/.../wsfed The following ensures that the Azure AD sign-in page redirects back to Microsoft Dynamics NAV correctly: - When Microsoft Dynamics NAV redirects to the Azure AD sign-in page, it dynamically adds a wreply query parameter. This is how Azure AD knows how to redirect back to Microsoft Dynamics NAV. - In some cases, the dynamically added wreply query parameter is not what you want. This is the case when the public URL is different from the private URL on which Microsoft Dynamics NAV actually lives. An example is when Microsoft Dynamics NAV is deployed in
