Previously Ax2009 and Sql server 2008 are in the same system.now we installed sql server 2008 are in another system.what my problem is how i connect to that database system in already existing instances (i.e ax installed system)?
I don’t have AX in front. But you should be able to point to the new SQL server in AX server configuration utility. Obviously first, you have to move the actual SQL database from old server to the new server.
I moved all databases then i run AOS to axsetup in server palce(application folder contain system) i have selected in server options new server instead of old server and port number is given to old one after installation is completed it shows AOS warning.I try to start ax service it unable to start.
