Your picture shows a client session (ax32.exe), not a server session. Seriously, you have to choose a server session (in the Session drop-down) to see the SQL tab.
In that case, the trace file you’ve imported doesn’t contain server trace and as you already know, SQL queries are not included in client trace files. You see that the problem is neither in Trace Parser nor in events you collect; the absence of server trace is what you miss.
Try to collect the trace on the machine where your AOS runs.
