I have using OS 2003 and configure two database in NAV 2009 R2:-
1- Cronus
2- Other Database
Configuration is correct two services running properly.Crouns database running Fine Screen shot atttached. Download the file and open
dynamicsuser.net/…/Doc1.docx.aspx
when i used other databse in same time but port is different the system says…screen shot is attached…Download the file
“Your program license does not permit more users to work simultaneously. Wait until another user has stopped using the program. Contact your system administrator if you want to allow more simultaneous users on your system.”
i have check the license in server installed location license is correct.
theconfiguratin is Right in my end.
Sunil Mishra
