I’m new to Nav (v 2009) and have a little question.
I’ve created a table where messages can be stored so that all users can see them. This table has the data per company-property on “No” so they are available in all companies. Now i’ve made a page wich contains these messages and integrated it in a role center page, so far so good.
What i want to do now is to add a condition to the page that only the lines where companyname is empty (=All companies) or where companyname equals the companyname in table 79 (company information) will be displayed on this page.
Never mind you are a beginner - this exact question is about coding, so I moved your post to Dev forum, there it’ll faster catch attention.
Not being a programmer myself, I can’t give you exact code, but the idea is to set a filter in code upon opening your page.
That’s not difficult, many derived Forms (now Pages) when opened as “drill-down” from some other form, use this approach.
Thanks for the suggestions. It’s indeed a better idea to use the COMPANYNAME-databasefunction.
I’ve tried to use Dhan’s suggestion to add WHERE(NameOfCompany=FILTER(COMPANYNAME|’’)) in the sourcetableview, but my idea is that NAV doesn’t recognize The COMPANYNAME-funtion as a database-function, but as a value. Do I have to specifie somewhere that the function i use is a databasefunction or something (I even tried this in a form without positive result)?
Finaly i needed to type one line of code in the OnOpenPage-trigger of my page. In this code, i check if the NameOfCompany-field of my table equals the COMPANYNAME (Databasefunction) or the constant ‘ALL’. Using databasefunctions in the sourcetableview-property is not possible.
