hi every one
i have suspicion on Flow Field in my requirement is in card i have to display the flow field when i drill down the flow filed the traction be appear but i have divided in traction why i am divided is this Flow filed add all the totals . i want aware of the which tranction belongs to which month and also this traction may be month total is suppose 1500 after next month this flow filed should be zero again user as send a transaction of that month so i know this is month
my scenario is give below. when drill down the Flow Field list be appear
this is 5 th month Transaction
Entry no date Description Amount
1 12/5/2011 &&&&&&& 1000
2 12/5/2011 &&&&&&& 1000
2000
Flow Field Be appear 2000 when i drill down the This List be appear
Next Month means 6 th month
1 12/6/2011 &&&&&&& 1000
2 12/6/2011 &&&&&&& 2000
3000
now Flow filed is appear the totals of 5000.but i don’t want this if i can go to next month the flow filed Must be zero
in case of any doubts i will explain you
thanks & Regards
Leeport
