Concern NAV Messanger
hi Doynes
any one can suggest me. i have doubt about NAV Messenger is it possible to chart in NAV Classic 2009 messenger why because in my client has took a NAV product They Want Local messenger in NAV because of Share information through the NAV Soft - Ware.
is it Possible In NAV?
Regards
Siva
Check this
http://www.mibuso.com/dlinfo.asp?FileID=567
hello mohana sir thanks for giving this URL .i have Downloaded objects& import in my Database version is Classic2009 SP1 .but Try to run the Form (50100) i face an Error i.e given Below
what should i do can u give details about messenger & how to run it . if we maintain any Server or it runs local system also
Microsoft Dynamics NAV Classic
The definition of the field User ID was changed after the object was saved.
Old type: Code
New type: Text
OK
please help me
Regards
Siva
Try recompiling the imported objects. Could be that the version of objects you downloaded are from different country NAV. (I have had this problem in swedish country database since Account number is in text instead of Code as it is in W1)
/Jinnis
thk q for giving This Information. i am very Full Field Your answer Currently it’s Working
Thanks&Regards
Siva
