Concat one string to a table field
I would like to Know how can I join in a table field one fixed string?
Ex: Field value = 2110
Strring = A
Result 2110A
Note: I Am using this C/AL :
Account_Code := (Account_Code+‘A’);
But like this the result is:
2110 A
How can I avoid this space?
I cannot but assume that these spaces are part of the field (Account_Code) value, so you need to remove these from the field.
Just tested the following code:
String := ‘2110’;
String := String+‘A’;
MESSAGE(’%1’,String);
with result showing: 2110A
Hy Luc
Yes the result in my message is 2110 A .
So, how can I avoid this space??
Either make sure users enter data without spaces or remove trailing spaces through code. For the latter have a look at the DELCHR string function.
The stange thing is that NAV, when entering data in a field, will remove trailing spaces automatically, so I wonder where they come from.
probably from the original import. I notice we had a ton of ending spaces when we first start nav especially in address & city fields.
delchr(yourstring,’>’,’ ');
