Kindly anybody explain me about the components of Dynamics AX
AOS
File server
Database
Client
Artata
AOS
File server
Database
Client
Artata
Hi Artata,
AOS = Application Object Server, it’s the core application that manages processes
File server = File server, don’t hear about that in AX, may be it’s the AOS because it contains application files
DataBase = Application database, where AX store all its datas
Client = local or remote program that open a session on AX, the user must be referenced in Active directory, you must have a functional domain to install and use AX
Both can be on the same machine but best practice recommend to use a dedicated server
regards,
Thomas
Dear Thomas,
Thank you very much for your reply.
Artata
