Comparsion of Integer Value in X++
I have an integer value for a field in database with 3. When i try to see if it is greater than 0 , it is skipping the conditional statement
My statement is ( if field > 0)
I see a value in the field with Watch window but it is showing up as x0003 instead of 3
Any ideas would be great…
hi,
where u r using that value ? if u r using the datasource in ur datasource node then just take that
if(datasourcename.field > 0)
Go to Google write your problem it gives you the best answer.
