Comparison Tool Attain 3.10
I am new to the Navision community, yet have a complex problem. I am a programmer/analyst for a mid-range company that has bought its leading competitor. We are in the process of consolidating the two businesses. The company which was acquired has been running attain since version 2.0 (now running version 3.10 A) and have made alot of specific modifications that have not truly been documented. The acquiring company is in the process of migrating to attain. I spent a week with my NSC trainer and he mentioned that there was a tool that could compare an Attain DB with the base model of the Attain DB for your License (.flf) file and produce the changes to the objects in the Database. Does anyone know of such a comparison tool and if so where would I acquire it. [?] Any help would be greatly appreciated, Thank you.
Hi, You can use any text comparision tool. You just need export objects from both systems in text format. Your NSC will do this for you.
Hi, There ia tool called File Comparision Utility(FCU) available to compare the files. You can download it from your NTR site.
Hi, There is also a thing called Navision Attain Developer’s Tool (License granules 120,xxx). It contains a very useful Source Analizer, which shows all the object relations in a graphical way, objects properties, triggers, … It also has an interesting Compare/Merge facility.
