I am preety new in Navision so if any one help me in this problem then i would really appreciate. What is a company Note? and how it is used. I know it is a kind of yellow pages which can be shared but how.??? Thanks in Advance
Hi, See the Navision Help for “Company Notes”. Follow the steps mentioned in help.
There is no Company Note Help avaiable. Thanks
Navision Attain contains a Company Notes feature. This feature allows you to write notes that are related to individual topics in the online Help. You must activate the Company Notes feature before you can write any notes. When you install Navision Attain, the Company Notes feature is installed but not activated. To activate the Company Notes feature, a system administrator must complete a series of steps, which are described later in this topic. Note When Navision Attain starts up, it reads the information that has been entered in the Company Notes Setup window. To open this window, click General Ledger, Setup, Company Notes Setup. The Company Notes feature will only be activated if this information is correct. When Navision Attain starts up, it checks whether or not the user is allowed to write files to the shared folder that is used to store the company notes. The user will only see the links for writing company notes in Help topics if they have write access to the shared folder. Because this information is checked when Navision Attain starts up, any changes that are made to the values in the window or to the folder access rights will only take effect after you restart Navision Attain.
