hii,
i created the processing only report and created the excel …
i want to get the data from all the companies…
i ceate two function for excel… first exceldataheader and put it on company’s on predataitem…and
second exceldatabody and put it on purchaseheader’s onaftergetrecord.
purchase header is indented under the company dataitem.
i use changecompany finction on Onpredataitems but it is not working…
what should i do?
it’s urjent…
could you supply some more information or even some code?
On which OnPreDataitem you have used the CHANGECOMPANY function ?
Hi, Why have you used company as a dataitem? Have you added the fields in DataItemLink property on Purchase Header table? I am not sure you will be able to provide DataItemLink to the system in Purchase Header DataItem.
You can do the following to achieve your desired output,
- Remove all the dataitems from the report.
- Declare Purchase Header and Company as record datatype global variables.
- On the OnPreReport trigger, add this code,
Company.RESET;
IF Company.FINDSET THEN
REPEAT
PurchaseHeader.CHANGECOMPANY(Company.Name);
IF PurchaseHeader.FINDSET THEN
REPEAT
// code to send data to excel …
UNTIL PurchaseHeader.NEXT = 0;
UNTIL Company.NEXT = 0;
Hope this helps.
