compability ax 2012 r2 CU7 with visual studio 2012
is there any way to get AOT on visual studio 2012 when i am using ax 2012 r2 cu7
No, there isn’t. But you can upgrade to R3 CU8 and use Visual Studio 2013.
ok , is there any way to use the visual studio 2010 with sql 2014 to design the ssrs? as BI tools of sql 2014 are not supported for VS 2010 and i am not able to edit the reports.
SQL Server 2014 is supported by AX 2012 R2 CU7.
Nevertheless you still need the old BIDS. Please see this thread for details: SQL Server 2014 and SSRS-Designer.
Thank you Martin for your quick resposes , i have tried with http://www.microsoft.com/en-us/download/details.aspx?id=36843 this SSDT , but i havent tried to install the BIDS with sql server 2008 r2 image file for visual studio 2010 , i will try using this option and let you know the result,
Again thank you man,
superb…thanx Martin it works
