Commerce Gateway
Hello, we are using Axapta 3.0 and already have a Biztalk 2002 in place. Can we import/export documents in axapta 1/ without commmerce gateway 2/ with commerce gateway but with CG on another server then BTS2002? Thank You for YOur reply.
Yes you can import documents in Axapta without CG; however, you must code the solution. If you use the existing code you only have to code the section to import / export the documents. CG comes in 2 parts. The server, which resides on the same computer as the BTS and the client part which should not be installed on the BTS.
Hi mctester, I have to start on a Commerce Gateway / Axapta project. However, I could not find much documentation and guides in the partnerguide. I am certified in Commerce Gateway / Navision, hence understand the concepts of the integration. Do you have the Training Manual or any other documentation (installion, demo script, getting started etc.) If yes, can I get a copy. It will be of immense help to me. Thanks in advance.
hi Sharma, have u started the commerce gateway. If yes please do guide me also, so that i can learn something on it with best regards vaibhav
Hi, If you look in the Technet, you should be able to find a document titled “Commerce Gateway” which deals with issues such as Installation, Post Installation, Schemas and mapping, etc. This document should give you some start. HTH, Harish Mohanbabu
Does anybody know how I can send an Axapta order (Purchase or Sales) to the Gateway Queue ???
hi all i have installed Axapta 3.0 with SP1, installed Biztalk 2002 evaluation 120 days copy, Commerce Gateway Server & client on the same machine – Windows 2000 Server. Now i want to work with it, i went through the technet commerce gateway document, but i am still confused , it may be as i am a dumb fellow (hehehehe), can anyone guide me, can i import the Commerce Gateway data which comes with Axapta 3.0 setup are there any steps to import the data. Also want to know can i use Axapta 3.0 Axapta Object Server & Commerce Gateway with Axapta2.5 Client. Please , any text on this is welcome. Thanks & regards vaibhav pednekar
