Hallo, I have tryed to use the commerce gateway on a database with two companies where both are using the commerce gateway with BizTalk Server 2004 on a navision database 4.00. When I send a document through commerce gateway so the message is allways received by the receive port “Navision_to_CommerceGateway” in BizTalk 2004 and I can’t determine from wich company the message comes of. How can I determine in BizTalk 2004 the company from where is coming the message? Thanks, Lukas
Hi Lukas, I can think of two approaches (not being very familiar with the standard Navision Functionality). Eihter add the Company-information to your Outgoing documents or use a different receive Port for your second company. Cheers Daniel
