Hi All, I am working on a Commerce Gateway project. I have setup BizTalk Server, Request Server, NAS Server etc. as per the documentation. Now when I goto GL → BizTalk → Management Setup and try to create the company in Biztalk, I get the following message “There is no contact with BizTalk Server”. Am I missing something or security setup. I have worked with Commerce Portal and User Portal and am familiar with NAS setup. Just a little help will push my project forward. Thanks in advance.
Hi Did you installed commerce gateway request server. If not you have to install that. If it is already installed then check your services. Suneetha
Hi, I have this working now, had to tweek the security settings. Make sure the Windows user is included in both the Administrative and Biztalk Administrator group.
