Comment Button
How to manage the comment button ? I don’t see the pencil image at design time and can’t find where it is loaded at run time !!! Thanks. Elisa.
Hi Elisa, Drag the button anywhere in designmode, then u will get a picture box that containt the Bitmap List. Do whatever u wanr to do there and then again put the button on right place. Cheers
YES ! It Works ! Thank you very much ! Bye. Elisa. [:D]
Another way - while in designmode - is to use Tab/Shift-Tab until you reach the desired control, thus avoiding moving the button. Normally Shift-Tab after having mouseclicked the button will do the trick.
How about selecting the front object and changing its property to “Send to back” ??
Huh? - which property is that?
It’s not a property. It’s a command in the Format menu. [:)] But I haven’t tried it, I’m not sure if it doesn’t mess up the comment button look. I also use the solution where you just drag the control a little to the side…
Oh yeah - never ever used it [:I] I guess you’ll have to send it back again after the first send it back [;)]
Yep [:D]
