Combo Box problem
Hello all,
I do not want to use enum field in combo box.
I have a field in a table, i need to fill the combo box with that value
I do not want to make it a dialog field also
Please reply me quickly
Thanks all in advance
Shankar
where you are using the control? You can build a lookup
Thanks for the reply Kranthi. I have resolved that issue
I am using the combo box control above the grid and using it for filtering the grid.
Now I have one more issue
There is a combo box and label field.
Combo box contains all the ids suppose. Now I want to display the name belonging to respective Id on the label.
I tried combo box overridden method such as selection change, gotFocus, lostFocus…but the issue which I am facing is as follows
eg: suppose in my combo box control there are 10 Ids but only the first Ids corresponding value is displayed on the label and not the other values… why I donno…
public void gotFocus()
Table table;
super();
select * from table
group by id;
ComboChange.text(table.IdName());
public int selectionChange()
int ret;
Table table;;
ret = super();
if(ret)
select * from table
group by id;
return ret;
Please advice
Hi kranti,
hope you are good.
can you please teach me how to create form in ax.
as I am not a developer but I am functional.
