Combine Shipment Functionionality in a BC Docker
I’m trying to finde the “Combine Shipment” functionionality on my BC installed on a docker. First of all, I’ve found that in the customer card, the “Combine shipments” field is not available. I read about this, and I’ve solved it changing the ApplicationArea.
But trying to find it in the search menu, I see this:
The “ombine Shipments” doesn’t appear. The report exists in the development environment, and if I run manuably the report, it works correctly.
But seeing this 2 issues, it seems that this funtionalityt isn’t operative yet… Is this right?
Thank you very much
