In Released Prod Order, against each released production order line (finished good) related components can be looked in the Production Journal as Consumption. Here in this Production Journal ‘Consumption Quantity’ can be changed and the Production Journal can be posted. and when we view the production journal next time system will show the remaining consumption quantity if at all there is any to be consumed.
And the above procedure happens line by line. (meaning for each production order line)
supposing if a Released Production Order has more than 2 Finished Good to be produced and supposing there is at least 1 raw material (component) common in both the finished goods.
the customer wants the components to be shown based on Production order (combining the quantity of the same item used in all the lines) rather than based on each item (finished good)
Eg:
Finished Good | 1952-W | OSLO Storage Unit/Shelf |
Raw Materials/ Components | ||
70000 | Side Panel tes | |
70001 | Base | |
70002 | Top Panel | |
Finished Good | 1928-W | ST.MORITZ Storage Unit/Drawers |
70001 | Base |
as shown above i use these 2 finished goods, create released production order and after the ‘calc. consumption’ report is run the consumption journal should show one line for raw materials / components 70000 and 70001.
with regard to this i wanted to know if this combining functionality is already available in navision?
thanks
