COM connector failed every time after 1h25m.
Hi.
I have made at WinService (C# ) that connectes to Axapta via Ax 3.0 COM connector every 20 sec. (Create instance, Logon, Logoff, Dispose COM from memory). After about 1h25m (every time - about 360 calls) the connector crash with this DrWatson error and my WinService is shut down:
“The error occurred on 04/16/2008 @ 16:19:40.385 The exception generated was 80000007 at address 00000000 (ntdll!KiFastSystemCallRet)”
And before abow, the COM Connector fails with:
"“Axapta COM Connector Session 40. Exception 0xc0000005 occured in thread 0x6554 handling session 40.”
Can someone explain to me why the COM connector runs fine for a periode and then crashes at the same time every time? Maybe it is my code that does it or is there another explaination?
/Janus
Hi Janus,
The first message looks like it is not from Ax - rather C# or IIS.
In any case, what version of SP are you running? Do you have any KR installed?
Harish
