I have a problem.
i want post multiple journal report as finished from button with single click?
is it possible ?
Thank your for your advice
I have a problem.
is it possible ?
yes u can do it ,by allow mutli select option on the button , go the button properties and select multiselect property to yes.
Hi Srikanth,
Thank you for your suggest.
i already tried u’r suggest.
that’s true the button is enabled but if i clicked Post, only the last journal that Posted.
Example :
I block 3 journal (a,b,c) only c that posted. a and b is unposted
is it true?
thank you
i think u need add multi -select code in button , ask any developer to do this task .
i think u need to add mutli select funcationally for this button , ask any developer to develop to do this.
