Code to export to a file to a specified folder with a specific file name e.g. ClientNameDateTime
I am trying to write some code to include in an export dataport that would set the folder location and a variable file name e.g. C:\TEMP\ClientNameDateTime?
I have also been led to believe by my vendor that Nav does not have a scheduler? Is this true? Are there any addons? What do other people do?
Any help is most appreciated.
Regards, Sue
I am Nav 4.0 user.
The Job Scheduler relative tables are #5980~#5982. To run Job Scheduler, it need one user login Nav and keep it running it 7-24 therefore it will occupy one user license. If you purchase the Service granules then you shall able to run the job scheduler. I am not sure you can purhcase granules for only job scheduler relative tables & forms.
Sue, instead of hard coding the path and file, add a field to a setup table, and program the dataport to retrieve it from there. That way, a user can change the default path/file without having to change the design of the object.
Den,
Thanks for the suggestion.
I have finally got back to this. I created a new field to hold the path & am trying to copy some code to create a variable name. I think I have it.
DateTimeText := FORMAT(TODAY,0,’<Month,2><Day,2>’) + ‘_’ +
FORMAT(TIME,0,’<Minutes,2><Seconds,2>’);
OutFile.CREATE(CompInfo.“ECN File Location” + ‘’ + DateTimeText + ‘ECN_Customer.csv’);
However, how do I then get the dataport to write to this file? Do I need to pass every record to a new field and then WRITE these fields to the file? Can I not just point the dataport to this new variable (in properties)?
Sorry, I am no developer (as you can see) and have a very limited budget - so can’t get my vendor to help as they would consider this consulting.
I am very frustrated as I used another ERP system and this was the easiest thing in the world - no development required! It also had an inbuilt easy to use scheduler.
Sue
Hi Sue,
This is a easy task.
  1. Modify the dataport to set the UseReqForm to “No”.
  2. Declare a variable of type Dataport and point to the dataport.
samples code:
MyDataport.IMPORT := false;
MyDataport.FILENAME := CompInfo.“ECN File Location” + ‘’ + DateTimeText + ‘ECN_Customer.csv’; // From your code
MyDataport.RUNMODAL;
You can also set the table view to use by
MyDataport.SETTABLEVIEW( MyRec );
Hi Dave,
Thanks for getting back to me. I have finally cracked it. Your code snippet pointed me in the right direction. I am forever grateful.
I ended up added the following code to the OnInitDataPort() -
CompInfo.GET(CompInfo.“ECN File Location”);
DateText := FORMAT(TODAY,0,’<Month,2><Day,2>’);
CurrFile.QUERYREPLACE(FALSE);
OutFileName := CompInfo.“ECN File Location” + ‘’ + DateText + ‘_’ + CompInfo.“Abbreviated Name” + ‘_Customer.csv’;
CurrDataport.FILENAME(OutFileName)
Sue
