When the SubLedgerJournalAccountEntryDistribution table getting the records.
Which means which classes or table methods to insert(Values) this table.
Anyone advise me on this
Have you tried cross-references?
If I look at references in D365FO, I see an inserts in SubledgerJournalizer.recordSubledgerJournalAcctEntriesDist().
Yes, Martin the SubledgerJournalAccountEntryTmpDetail table inserts the records to SubLedgerJournalAccountEntryDistribution. But I have to insert SubledgerJournalAccountEntryDistribution this scenario SubLedgerJournalAccountEntryTmpDetail table does not have the respective records. So you have any idea SubledgerJournalAccountEntryEmpDetail table how they getting the records…?
I would again use cross-references. Have you tried them?
Yes, I have checked cross-reference on this SubledgerJournalAccountEntryDistribution table to insert records only in SubledgerJournalizer.recordSubledgerJournalAcctEntriesDist(). You have any idea about when they are called SubledgerJournalizer class…?
