Please can I get some ideas on below issue.
version: NAV 2013 R2
issue: Page ID 5076 - Interaction Log Entries has some code in OnAfterGetCurrRecord where code that loads and displays comments in the FactBox Comments (linked to record of T5065 - “Interaction Log Entry”) and another code in OnAfterGetCurrRecord of same page saves edited content of comments crashes the NAV client as user sorts on any column of PG5076 - “Interaction Log Entries” There is some Add-in executed as FactBox (page Comments) is being loaded.
User steps:
Open NAV
Go to Contacts → Page Contacts is displayed as expected
select any contact → record is selected as expected
click on NAVIGATE → click on button “Interaction Log Entries” →
Page ID 5076 - “Interaction Log Entries” is opened as expected
record of contact interactions are loaded as expected
FactBox “Comments” on Page ID 5076 is displayed as expected
- the code in PG5076 - OnAfterGetCurrRecord runs below code:
CurrPage.editPart.PAGE.SetBT(xRec."Entry No.");
CurrPage.editPart.PAGE.GetBT("Entry No.");
as user selects a record in PG5076 code checks if any comments exists for that entry (record) and then loads these comments in the FactBox Comments,
as user edits (insert, modify, delete text/content) comment second line of code saves the comment
procedure SetBT and GetBT runs Add-in which is handling loading and saving part of comments
- User clicks on any column of PG5076 to sort records from ASC or DESC (by the column user clicked on)
- if there are no comments for any entry (record) of PG5076 everything works as expected
- user can filter on any column of PG5076 and NAV client does not crash, but works as expected
- if there is any comment on an entry it is being loaded as user selects that entry (record) - Column Comment is set to YES if any comment exists
if user edits loaded comment, the content of comment is save as user selects another record or closes the page (CurrPage.editPart.PAGE.SetBT(xRec.“Entry No.”)
if user tries to sort on any column where at least 1 entry (record) has a comment then the NAV cline freezes and NAV client crashes.
issue is not present if I remove upper code from PG5076 OnAfterGetCurrRecord to OnAfterGetRecord, but then all the comments are being loaded (I know why the comments are loaded and I do not want such behaviour).
Thanks for any suggestions.
