CODBC-Driver for Linux and Financials 2.01.A
Hello, is there a CODBC driver for Linux and Navision Financials 2.01A available? How else can I get data under Linux from a Financials database which runs on a WINNT machine? Rolf
Hello Rolf, no ODBC-Driver for Linux [:(]. To connect our Webshop (Java on Linux) with our Navision installation we are using the JDBC-ODBC-Bridge from Easysoft.
Rolf, As a cost-free solution, I was able to install Zope on Nav WinNT server, use C/ODBC to return data from Nav to Zope, then return data to Linux via HTTP. I then use PHP on Linux to display the information in a webpage.
You can find some more details performing a search for “linux odbc”, especially this topic might interest you: http://www.navision.net/forum/topic.asp?TOPIC_ID=347 Saludos Nils
