Client callbacks are not supported on Microsoft Dynamics NAV
Hi everyone,
I am trying to run a codeunit through a job queue.
The codeunit enables to send notifications to employees via mail using the function NewMessage in codeunit 397.
I am having the following error:
Microsoft Dynamics NAV Server attempted to issue a client callback to create a DotNet object:
Microsoft.Dynamics.Nav.Integration.Office.Outlook.OutlookMessage (CodeUnit 397 Mail).
Client callbacks are not supported on Microsoft Dynamics NAV.
What can I do to fix it?
Please check f outlook is properly installed on the computer that you are running the jobs also configure a admin user with outlook.
Anil.
Which version of NAV is this?
I’ve the same problem in NAV2013. I’ve created a codeunit which uses the DotNet variabele below to send e-mails:
Microsoft.Dynamics.Nav.Integration.Office.Outlook.IOutlookMessage.‘Microsoft.Dynamics.Nav.Integration.Office, Version=7.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’
Propertie ‘RunOnClient’ has the value ‘No’.
When I want to run de codeunit through a job queue I get the error
Microsoft.Dynamics.Nav.Integration.Office.Outlook.OutlookMessage (CodeUnit 50000 test html mail).
Did you try by setting
Propertie ‘RunOnClient’ to ‘yes’.
Hello,
Did anyone find a solution for this? I’m experiencing the same problem.
Best Regards
Emil
