Hello Colleagues,
Just completed the ClickOnce deployment setup, but keep running into this error message whenever I click on the deployment link: Application download did not succeed. Check your network connection, or contact your system administrator or network service provider.
Problem is I also tried running this from the server itself and got this same error.
Your suggestions would be very helpful.
Thanks in advance.
See below additional details of error:
PLATFORM VERSION INFO
Windows : 6.2.9200.0 (Win32NT)
Common Language Runtime : 4.0.30319.34209
System.Deployment.dll : 4.0.30319.34274 built by: FX452RTMGDR
clr.dll : 4.0.30319.34209 built by: FX452RTMGDR
dfdll.dll : 4.0.30319.34274 built by: FX452RTMGDR
dfshim.dll : 6.3.9600.16384 (winblue_rtm.130821-1623)
SOURCES
Deployment url : file://10.0.160.15/Fileshare/ClickOnce/Deployment/Microsoft.Dynamics.Nav.Client.application
Deployment Provider url : file://fileshare/clickonce/Deployment/Microsoft.Dynamics.Nav.Client.application
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
- Activation of \10.0.160.15\Fileshare\ClickOnce\Deployment\Microsoft.Dynamics.Nav.Client.application resulted in exception. Following failure messages were detected:
Downloading file://fileshare/clickonce/Deployment/Microsoft.Dynamics.Nav.Client.application did not succeed.
The network path was not found.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
- The manifest for this application does not have a signature. Signature validation will be ignored.
OPERATION PROGRESS STATUS
- [26-Feb-16 1:10:37 PM] : Activation of \10.0.160.15\Fileshare\ClickOnce\Deployment\Microsoft.Dynamics.Nav.Client.application has started.
ERROR DETAILS
Following errors were detected during this operation.
- [26-Feb-16 1:10:48 PM] System.Deployment.Application.DeploymentDownloadException (Unknown subtype)
Source: System.Deployment
Stack trace:
at System.Deployment.Application.SystemNetDownloader.DownloadSingleFile(DownloadQueueItem next)
at System.Deployment.Application.SystemNetDownloader.DownloadAllFiles()
at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState)
at System.Deployment.Application.DownloadManager.DownloadManifestAsRawFile(Uri& sourceUri, String targetPath, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadManifest(Uri& sourceUri, String targetPath, IDownloadNotification notification, DownloadOptions options, ManifestType manifestType, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirect(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.FollowDeploymentProviderUri(SubscriptionStore subStore, AssemblyManifest& deployment, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
— Inner Exception —
System.Net.WebException -
Source: System
Stack trace:
at System.Net.FileWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Net.FileWebRequest.GetResponse()
— Inner Exception —
Source: System
Stack trace:
at System.Net.FileWebResponse…ctor(FileWebRequest request, Uri uri, FileAccess access, Boolean asyncHint)
at System.Net.FileWebRequest.GetResponseCallback(Object state)
— Inner Exception —
System.IO.IOException -
Source: mscorlib
Stack trace:
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync)
at System.Net.FileWebStream…ctor(FileWebRequest request, String path, FileMode mode, FileAccess access, FileShare sharing, Int32 length, Boolean async)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
