You forgot to add the content of your question, such as an explanation of what you’re trying to achieve and what problem you have with it. Please fix it.
1- go to AOT
2-open the classes
3-search on SysDatabaseTransDelete class
4- right click on the this class
5-choose open
6-click yes on the message box appear to you
7-info will appear to you "operation completed"
This will delete all the transaction inside any company.
Dear Martin,
Thanks for that. I did write but somehow it never posted on the forum.
Here goes:
I have tried to clear data in a company in AX using AOT using the class Action SysDatabaseTransDelete. But after running the above command, I still find there are transaction left in the Fixed Asset Register. All other transactions are cleared.
I was wondering if there is a way to clear the Fixed Asset transactions.
Thanks in advance.
ALIHUSSEIN
Do you mean the AssetTrans table? If so it is a transaction table, so the class should also delete the records (i dont even see any aos validation during the delete).
