HI
I am passing the PurchId from Purch Table to Report in MenuButton clicked mthod
in Report I am getting in this way:
public void init()
try
if(element.args().parm())
this.query().dataSourceTable(tablenum(VendPurchOrderJour)).addRange(fieldnum(VendPurchOrderJour,PurchId)).value(element.args().parm());
_PurchIdBase = element.args().parm();
this.query().userUpdate(false);
this.query().interactive(false);
super();
catch(exception::Error)
info(“Errosr in init”);
getting properly.
In the RunBase window the range is not changing. Means 1st wt I have selected the PO that PO Num only taking all ways. how resolve this.
can any body help me…
Thanks in advance…
kranthi
2
Use initFromCaller method. See InventJournalTrans report for reference…
In my scenario how can I do this?
try this it would work…
public void init()
PurchTable purchTable;
try
if (element.args().dataset() == tablenum(PurchTable))
purchTable = element.args().record();
if(purchTable)
this.query().dataSourceTable(tablenum(VendPurchOrderJour)).addRange(fieldnum(VendPurchOrderJour,PurchId)).value(purchTable.PurchId);
_PurchIdBase = purchTable.PurchId;
super();
Naresh Kolli
I am getting output, but the problem is if i select one PO.
getting proper po lines.
if I close the report and select one more PO . report range previous range is not changing it the previous range PO items only getting in the report…
PurchTable = element.args().record() will always get the latest selected Purchase Order. Try debugging your code. I guess you missing something.
kranthi
8
Are you getting the PurchId value in the init method?
kranthi
10
Then there could be a problem in sending it as value to the range.
Try by placing your code after super();
If even that doesn’t work try this code init method.
QueryBuildDataSource qbds;
qbds = element.query().dataSourceTable(tablenum(VendPurchOrderJour));
sysquery::findOrCreateRange(qbds,fieldnum(VendPurchOrderJour,PurchId)).value(YourPurchId);
