Clear Lines after posting in Item Journal
Hi to all ,
I am Learning the navision please help me in this…After posting a Item journal (it is a customised form), last posted doc no and date are still remained in the lines. So how to clear those fields? please help me …
Thanks in advance…
Awaiting reply
In CodeUnit 23,
Comment the below code
IF (ItemJnlBatch.“No. Series” = ‘’) AND NOT ItemJnlLine3.FINDLAST AND
NOT (ItemJnlLine2.“Entry Type” IN [ItemJnlLine2.“Entry Type”::Consumption,ItemJnlLine2.“Entry Type”::Output])
THEN BEGIN
ItemJnlLine3.INIT;
ItemJnlLine3.“Journal Template Name” := “Journal Template Name”;
ItemJnlLine3.“Journal Batch Name” := “Journal Batch Name”;
ItemJnlLine3.“Line No.” := 10000;
ItemJnlLine3.INSERT;
ItemJnlLine3.SetUpNewLine(ItemJnlLine2);
ItemJnlLine3.MODIFY;
END;
but can we comment standard code?
as per your requirement, you have to…
welcome…
Please Don’t forget to VERIFY the post(s) that solved your problem.
Hi
Check the “SetupNewLine” function in the table 83(Item Journal Line)
Jerome Marshal. J
ya thanks mars its solved
