Class changes doesn't take affect on client.
I have changed a class.
Everything is fine,
but when a client runs the Dynamics AX, he cannot see the changes, even he closed the Dynamics AX program, and reopenned it again.
What may be the reason for that ?
Thanks :slight_smile:
Try to delete local cache file ( *.auc ) on client machine.
Should I do : Stop+Run to AOS service (Dynamics AX object server) ?
No
The auc file was on the server, so I need to delete it on the server - in that occasion, I did stop+run the the AOS service.
That’s work, great - I couldn’t find it otherwise.
Thanks you [:)]
On client machine in folder C:\users\currentUser\AppData\Local
It`s path right for Windows 7.
