My client is using Citrix to access Navision(IN Nav 4.0SP3 Ver).
While sending Mail with PDF attachment. Navision will hang for some time. If user access navision without Citrix then its working fine.
Can any one suggest me how to improve the performance of Citrix by which navision will not hang.
My guess is that you are using your locally installed PDF printer driver to print it to. Try instead to install the PDF printer driver directly on the Citrix server.
