Hello All,
A few questions, look forward to some expert advice.
Q1: We are trying to move to a citrix environment. When you launch AX through citrix, where does it load the client configuration file from (citrix client or end user desktop) ?
I the following server-client setup for our ax environement:
client → ax application server(ax1) → ax SQL server → SAN
I also have a backup ax application server (ax2).
Q2: If ax application server (ax1) goes down, will I have to update every client config file on every desktop to connect to ax2 or will I only have to modify only the citrix client config?
Q3: Is there a way to achieve that redundancy without doing a cluster of the ax application server and achieve an automatic failover to ax2?
Thank you in advance.
