Hi all! I’m trying to print cheques from the CA Adv. Distrib. 2.50 version using report 1401. The client wants to print the cheque on the lower third, and the stub on the top two thirds. Currently the report is printing the cheque in the middle third of the report. I thought there was a value somewhere that I could adjust to have the cheque print atr the bottom, but Navision support says I must re-write the report. Any suggestions?
The standard US check report (also #1401) prints the check on the bottom third of a 8.5-by-11 in page. Have you figured out whether this is a custom Check report or the shrinkwrapped check report which you are currently dealing with? ------- Tim Horrigan
Matt, Check the last section in Report 1401 “Print Check Footer(1)” and make sure that the “PlaceInBottom” property is set to Yes. Marcus Marcus Fabian phone: +41 79 4397872 m.fabian@thenet.ch
Many thanks for your help. I managed to resolve the problem by purchasing an Add-on from Aston-IT - Ontario California (formerly Titanium Business). The tool works very well, and support was excellent.
