I am restoring and FBK backup of a large Navision/SQL database from tape. When the backup was taken, FBK was split up into several 2GB files. I have restored the fbk files from the tape into a new directory. At some point in the restore (the end of the first FBK file I think), the restore fails indicating there has been a checksum error. Any suggestions?
Aferg, You should make a SQL Back up in place of a fbk within Navision. So point your database in SQL entreprise manager and clic on… Back up database. This will be much more faster. Certainly if you work with a (some)big database(s) Regards John
