Checking Product Dimensions
Is there a quick way to look through the Product Dimensions of our Inventory at once, instead of using ctrl+shft+D on each item seperately? I do not believe NaVision has a report for this function, and showing everything on the Item list will not show the dimensions either. As an alternative, is there a way to create a report to reveal all the dimensions associated for each product? I am relatively new at report writing for NaVision, so excuse my ignorance. [:D]
Hi, You can use the “xxx Dimension” tables (from ID-355 to ID-359) as per your requirement to generate the report. I hope once you will see the data in these table you understtod the logic how to generate the report.
