CHECKING DUPLICATE DATA ON EMPLOYEE RECORD
Hi Folks,
I am using Dynamics nav 2013 and I want a way prevent duplicate
data from being accepted into the employee record when a new entry
is being made. I tried the code below but without success:
BEGIN
IF emp1.FINDSET THEN
REPEAT
emp2.SETRANGE(“Social Security No.”,emp1.“Social Security No.”);
IF emp2.COUNT > 1 THEN
EXIT(TRUE);
UNTIL emp1.NEXT = 0;
EXIT(FALSE);
END;
What are you using as your employee no? The key field is there to help prevent duplicates.
you can use something like the fist and last initial plus the last 4 digits of the social as the number.
like HR1234 - highly unlikely you’ll get two that match. You can always go last 5 digits if you want to be super sure.
I think you should do a emp2.RESET before the emp2.SETRANGE(…).
Try that and see if it solves your issue.
Jose.
Try that and see if solved your issue.
Jose.
Hi Eddy,
Try this, this shall perform what you want
