we recently built our own Navision-BuildServer which generates Releases and Patches from the VSS and checks if these patches compiles under Navision. But we have a big problem within this release-process. The Navision Compiler does not check Calcfields and SetCurrentKey-Statements. This causes runtime-problems if we remove a Key or make flowfields to normal fields.
Maybe anybody has a solution to check these problems with a small tool or something like that.
I know that this is possible with the Developers Toolkit - but automaticly generating a DevTool-DB with the new release needs a lot of time so that this is not the first choice within a build-process which will be run very often.
forki
