Check selected column values are same
How can we check whether the column values of the selected rows are same?
For e.g.i have a form which has 10 customer transactions,and i’m selecting 4 out of 10.And when i select a button it should check whether the “customer name”(column) for the selected columns are same.
Rajee
For example:
MultiSelectionHelper selection = …
MyTable t = selection.getFirst();
str firstValue = t.Value;
while (t)
    if (t.Value != firstValue)
        return false;
    t = selection.getNext();
return true;
Thanks Martin!! It works fine…
Below is the code which i used
public boolean checkSelectedVendorSame()
CustTrans mytable
MultiSelectionHelper helper = MultiSelectionHelper::construct();
str customer;
boolean ret = true;
helper.parmDatasource(mytable_ds);
mytable = helper.getFirst();
customer = mytable.CustAccount;
while(mytable)
if(mytable.CustAccount != customer)
ret = checkFailed(’@INA2121’);
break;
mytable = helper.getNext();
return ret;
