Where is check date coming from? How to make today’s date to payment date on payment check?
Hai Eclipse. As Per My Knowledge While You Giving The Payment For A particular Vendor You suppose to mention the date in Vendor Payment Lines. If you want to change the date You can change it from Here only… The system will generate the check based on payment date only…
First You need to select an Invoice
Second you need to verify the dates which date you want to pay?
Check Will be generated as you given date finally.
When using payment proposal window, where should we enter payment date (check date) ?
Total Payment Date field.
