I need to download check information from Navision to Excel, to send to my bank. What table/tables should i use?
You can check Bank Ledger Entry Table for the same.
Thanks for the reply. I am new and unfamiliar with Navision, would you happen to know that table name?
Also look at the “Check Ledger Entry” table #272 - to see if it has all the info you need
you can also see that data in the check register.
You can even simply set filters to show the data you want & copy & paste into excel.
Unless your looking to build some kind of export function.
