Check Dimension Code blank
Hi Eveybody,
When add code on UnitCode use check Dimension Code on Sales Line then not work
SalesLine.RESET;
DimCode.RESET;
SalesLine.SETRANGE("Dimension Set ID",DimCode."Dimension Set ID");
DimCode.SETFILTER(DimCode."Dimension Code",'SKU');
IF DimCode.FINDSET THEN BEGIN
  REPEAT
    DimCode.TESTFIELD(DimCode."Dimension Value Code");
  UNTIL DimCode.NEXT = 0;
END;
Please help me fix code. Thanks so much.
You can add this code on Release of Sales document codeunit.
Salesline.reset;
salesline.setrange(“document type”,“document type”);
salesline.setrange(“document no.”,“no.”);
if salesline.findset then begin
repeat
salesline.testfield(“shortcut dimension 2 code”) //Or whatever dimension you are checking.
until salesline.next = 0;
end;
Thanks for the reply.
But with shortcut dimension 2 code and shortcut dimension 1 code it’s Ok. I wan’t search in table Dimension Set ID (table 480). Because In addition to the (shortcut dimension 1 code, shortcut dimension 2 code) I use the shortcut dimension Sku.
Thanks so much
glsetup.get;
dimsetentry.reset;
dimsetentry.setrange(“dimension set id”,“dimension set id”);
dimsetentry.setrange(“dimension code”,glsetup.“shortcut dimension 4 code”);
if not dimsetentry.findset then
error(‘Dimension code %1 not found’,glsetup.“shortcut dimension 4 code”);
Thanks you sbhatbng.
But it’s not work, Although the SKU is not empty, it still receives an error message “Dimension code SKU not found”
Hi
Can you please share attached dimension set id vales please.
glsetup.GET;
dimsetentry.RESET;
SalesLine.RESET;
SalesLine.SETFILTER(Type,’>0’);
SalesLine.SETFILTER(“Gen. Prod. Posting Group”,’<>POSM’);
dimsetentry.SETRANGE(“Dimension Code”,glsetup.“Shortcut Dimension 4 Code”);
IF SalesLine.FINDSET THEN REPEAT
dimsetentry.SETRANGE(“Dimension Set ID”,SalesLine.“Dimension Set ID”);
IF dimsetentry.ISEMPTY THEN
ERROR(‘Dimension code %1 not found’,glsetup.“Shortcut Dimension 4 Code”);
UNTIL (SalesLine.NEXT=0);
